RatedR »
https://forums.nicoclub.com/ratedr-u4104.html
Sun Sep 17, 2006 5:24 pm
Alright, I just came back from the guy's house and no luck. I've triple checked the timing, reset the CAS, adjusted it while giving some throttle input (Second timing mark from the left) and NOTHING. I've also clean out the screw and the IACV, but I wasn't sure where you wanted me to put the wood to hit, so I skipped that. I checked his ECU, its a J4 for a redtop and doesnt have the diagnostic screw in the back to pull the codes from. Could that possibly be the problem? Should the ECU be an E5 or a J4 for a redtop?
Oh, and I noticed a small vacuum nipple coming from under the throttle body. Does that go anywhere? Everything else is plugged into something, just that nipple.
PS - would it help to take a video clip and post it?
