Now for the problem. I followed the procedure closely. The TPS was very linear from 2k ohms to 10 k ohms. At normal running temp, I adjusted the voltaage to .50volts (midway between the .45 to .55 range) . I disconnected the harness to the TPS and reconnected per the procedure.Next, I disconnected the harness again. I adjusted the IAA to 650rpms. When I reconnected, the rpms went up to about 1700 rpms. I took the car for a drive. Every timr I stopped for a stop sign, the RPMs went to 750rpms immediately. When I went home. I pulled into the driveway. Killed the engine and restarted, the rpms went to 1700. My son used th ecar last night. when I talked to him this morning, he said it idled at 1700 most of the time. When I drove it to work this morning and had to stop., It idled at 1700 about two thirds of the time. The other third it would idle at 750.
Oh yea, I've checked ALL the hoses and vacuum hoses. No problem there. Any of you guys have any ideas???
