rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Fri Dec 24, 2004 8:51 am
I have the Newest model NISMO 555cc inj which have been flowed tested to 615cc inj. My jwt ecu is programmed for the Z32 maf and the 555cc inj (but jwt knows about the newer nismo inj and he asked me if i had the new ones or the older style one's, that way the program was tunned to the correct flow rate)I have the sfc 2 but its not tunned yet. Im waiting on the dyno run and my wideband O2 so that I can tune it. As far as the dec-air function, it did not work. I had one guy on freshally go thru it with me like 4 posts long and it would not work for anything. When i was tunning it to the idle, the motor would respond like it was supposed to, but when i got out to test drive, it stalled out at every light and every stop sign. I gave up on it eventually.
Now to the stalling problem:All the blame is toward the jwt ecu programming. We all know that the jwt ecu is not the best tune in the world. But it works its purpose. All their concern is toward WOT and to make sure that the motor stays "HAPPY" under full boost. But under idle, thats another story.
Their 370cc inj program has the smoothest idle simply cause your only running 370cc inj vs stock 270cc inj. The same amount of fuel is dumped at idle speed, therefore the idle is smooth and we can run OPEN atmposphere bov without having any stall out issues.
The 555cc (50lb) AND the 740cc inj (72lb) inj programs however are not so good at idle. Why, well cause their program for some reason ADDS more fuel at idle. They have not corrected or maybe even figured out how to maintain the same amount of fuel flow as the stock ecu does on the stock 270cc injectors. (maybe they dont care, who knows) Being that these larger inj programs ADD more fuel at idle, this causes the mis-fire and irratic idle problems. Why, well cause the STOCK (S14's internal coil) ignition is not strong enough to ignite the fuel mixture from the added fuel dumped at IDLE only. This causes a slight mis-fire at idle. When u get a large enough mis-fire the motor will dop idle down far, then the IACV will try to compensate, then the motor will raise back up, another mis-fire will occur and the idle will drop back down, and this entire cycle will continue unitl the motor drops down far enough to stall out...Now, when u hit the gas pedal to raise up the rpm, the ignition will amplify and ignite MOST of the mixture to a point that u will not FEEL any more mis-firing. However the ignition is still not strong enough to ignite 100 % of the mixture, even at WOT..
The only cure to fixing this rough idle and to KEEP the jwt ecu prog is to get an MSD ignition box... OR just dumping the jwt ecu and going stand alone with a better ignition system.
I went with the MSD ignition box and it stopped the mis-fire, my idle is now smooth as can be, and i felt a nice huge gain in power at wot.
Next: the stalling issue at stop lights and stop signs was also directly related to the extra fuel at idle and because i was running open atmosphere bov. Being that all the air was dumping out WITH the added fuel dump, the ignition had no chance to keep the motor alive..So i just recirculated the bov and that fixed the stalling, now since then the motor has NOT stalled one time..!!
The rough idle was figured out by one of the ka-t.org guys that ran into the same problem and it took him weeks to figure it out. He is one of the few guys that r putting down 500+ rwhp.The stalling issue was figured out by a member on freshalloy who happened to read my post. Apparently my greddy type S bov needs to be internally modified to run as a recirc bov..
I dont know how these guys figure this out, but they did and i thank them all...!!!!!!!!!!!!!!! And to think that I was ready to sell this freakin car cause i was so fed up with these problems...
Ok, thats enough on my end...
