Idle problem?
sr20detspec
My 240 with sr20 motor idels funny and my motor will vibrate crazy any ideas?
AX75F92
Car: Space
running on 3 cyl? check spark and injectors.
bad afm? could be a lot of things...all of which i had the enjoyment of dealing with when i completed my swap.
easy way to tell if you are on 3 cyl: go down the line unplugging one injector at a time with the motor on. If you unplug one and there is no change in the idle...thats your culprit.
good luck. fun times.
