dickiesmalls »
https://forums.nicoclub.com/dickiesmalls-u213532.html
Tue Dec 18, 2012 4:46 pm
Here is my issue or how it started and where I am at now. I have a 2000 nissan maxima se. It began to stall at red lights or at idle. This was very intermittent but once it started to act up it would do it consistently during the drive. I had a guy try and do and idle air relearn and it wouldn't complete. He said it was the iac. So i replaced it with a standard motor products after market one and it still wouldn't do a relearn. I then replaced the tps and tired a relearn with no luck. I put the old one back on. I then cleaned the mass air flow sensor and throttle body value, replaced the spark plugs and coils(after market) and it finally did a relearn after about 15 attempts. After doing a relearn it idled fine for a few hours then started back having issues. Now, not only does it have idle issues I am getting about 18 mpg. It also will do like an idle surge where the rpms will jump while it is shifting between gears but is very intermittent. If I hold the rpms at 1500 it will jump or bob up and down. If I rev it up to about 2500 rpms and let it drop it will try to catch it self to idle but it either stalls or catches it self at like 200 rpms. I decided to take it to a dealer and they said I had a bad mass air flow sensor, a bad rear heated 02 sensor and a bad engine control harness. Total of about $3000. The codes I have are P1320, P0139, P0138. I never saw the P0505 code. I have read a lot here where people have had to replace the ecm because of the iac, but the dealer said they tested the ecm and it was fine. I need some help. Could an after market iac cause all of this? Could it be the mass air flow and o2 sensors? Below is the data monitor info I got from the dealer.
Eng Speed 0 rpm
MAS A/F SE-B1 1.32v
A/f ALPHA-B1 100%
A/f ALPHA-B2 100%
HO2S1 (B1) 0.00v
HO2S1 (B2) 0.00v
HO2S2 (B1) 0.29v
H02S1 MNTR(B1) LEAN
H02S1 MNTR(B2) LEAN
