jspecnitemare »
https://forums.nicoclub.com/jspecnitemare-u12609.html
Mon Mar 15, 2004 7:55 pm
Hey everyone... Iv'e searched and searched...and I can't fix my problem so here goes:
I have a 89 (KA24E) with severe idle problems. When I start it up, the idle goes to about 1500, then after about 30 seconds it stalls out. It is drivable, although very difficult because I cannot rev past about 3000 rpm or it becomes a mechanical bull. Also, if I let off the gas, it will die. I serviced the AAV valve, located behind the intake manifold and I have also cleaned MAF using a q-tip and rubbing alcohol. After cleaning it, it lasted a little bit longer but eventually gave out. The fuel filter has recently been replaced with a 300zxTT one, so I don't think it's that. Any answers would be awesome, thanks.
