Darius »
https://forums.nicoclub.com/darius-u5470.html
Tue Dec 02, 2008 3:50 am
Is it running of the stock ECU or an aftermarket ECU or piggyback system?
Here is the verbage in the FSM about how idle is controlled:"The ECM controls the engine idle speed to a specified level through the fine adjustment of the air, which is letinto the intake manifold, by operating the electric throttle control actuator. The operating of the throttle valve isvaried to allow for optimum control of the engine idling speed. The crankshaft position sensor (POS) detectsthe actual engine speed and sends a signal to the ECM.The ECM controls the electric throttle control actuator so that the engine speed coincides with the target valuememorized in the ECM. The target engine speed is the lowest speed at which the engine can operate steadily.The optimum value stored in the ECM is determined by taking into consideration various engine conditions,such as during warming up, deceleration, and engine load (air conditioner, power steering and cooling fanoperation, etc.)."
It then lists possible causes in a table on page EC-424 as being:1) Electric throttle control actuator2) Intake air leak3) PCV system
Keep us posted.
