dmtx240sx »
https://forums.nicoclub.com/dmtx240sx-u97342.html
Tue May 20, 2008 7:28 am
Hey every1 im new to this site. I have a 93 240sx just swapped in a sr20det redtop. The car has a crazy idle it will go from 1000-2000 rpms it will stay at both for about 5 seconds and then switch back to the other. Doesnt die, does this with the engine cold or hot doesnt matter. I thought it was the MAF did some searching on here said try to start car then unplug MAF if the idle dont change prolly not ur prob. when i pulled it car died. Tried to do the carb cleaner in the AIC valve not change also sprayd sum on my MAF sensor thinkin maybe it had sum dirt or build up on it. I dont know what else to do any suggestions
Modified by dmtx240sx at 12:02 PM 5/20/2008
