rally56 »
https://forums.nicoclub.com/rally56-u2304.html
Mon Aug 04, 2003 1:55 pm
HI, I'm experiencing a severe idle problem with a 91 240sx. Here is a brief history: Rebuilt the engine at 165k, used 89 pistons for higher compression, removed a bunch of emissions stuff, including the box on the drivers side, the butterflies in the manifold and their vacuum hoses and appurtenances.removed the clutch fan, ported and polised the heads and matched the intake manifold. installed hotshot headers, apex n-1 exhaust, hi flow cat, injen intake. Lastly, i installed a zex NOS kit, but never had a chance to try it. While i was still breaking in the motor,(<2K) the radiator cracked, the car overheated and i have been having the idle problem since that time. it ran like a bat out of hell before this. I did a compression check and found almost no pressure on the #4(60psi). the rest were at 180. i thought that this was the problem. We pulled the engine and removed the pistons. #2 & #3 had broken middle ring landings and the #4 had first and second landings broken. No explanation for this.(Possible detonation) put engine back together with 91 pistons this time but it still would not idle. checked all remaining vacuum lines, replaced temp sensor, iaa, pressure regulator, spark plugs, cleaned egr, checked injectors. still not idling. last thing is the MAS, but at $400 i want to be sure. Any suggestions? Help, PLEASE!!
