idle problem
0_e
Car: 95 240sx
my car is idlen around 1500-1800rpm..and iuno how to turn it down..can someone help me??
i would try to adjust the idle w/ the idle adjust thing but iuno where it is..
Hijacker
Car: '92 240sx Convertible
'94 F-150
The idle adjust screw is located on the intake mani. It's usually located near the back of the intake plenum. I'm not familiar with S14 KAs, so I'm not certain if the access position is the same as on S13s
vancouverbc
Car: 1991 240sx
Has it always idled that high? the idle adjustment screw cant adjust if you air reg is stuck open or temp sensor is broken etc.
first thing would be to clean throttle plate area.
look up idle in tutorial link in my signature. do search of high idle in forums
0_e
Car: 95 240sx
would it be in the same place if i have the greddy intake manifold?
0_e
Car: 95 240sx
its been doin it for a couple of weeks now. aite thanks mang
ZiG
Car: 1993 240sx coupe
probably. why dont you go look.
0_e
Car: 95 240sx
would it make a different if i have an sr20det motor?
ZiG
probably. I think it's on the bottom in the middle of the plenum. why dont you go look.
vancouverbc
Car: 1991 240sx
I'm not sure but the idle adjustment screw is not going to help you out. You need to find out where the extra air is coming from ie stuck throttle plate, open air regulator, hole in vacuum tubes, faulity iacv, throttle cable snagged, etc.. You always clean your throttle first in case like this.
0_e
Car: 95 240sx
aite thanks,i will look into the tips
