compression »
https://forums.nicoclub.com/compression-u9345.html
Tue Mar 11, 2003 8:08 pm
Your search was unsuccessful most likely because I made up those terms, I am not sure what the official names are, look in the fsm.I ran mine without the water lines hooked up to the idle motor. It would not idle below 1050 RPM, even with the idle motor shut. I am using a stand-alone and have complete control of this, thats when I discovered that the valve needs water to close an auxilary passage that the air is let through.After taking 10 minutes to plumb the water through that valve, it now idles at 800-850 RPM when warm with no changes to the software. So it did run fine without that water line the 10minutes of work and 16" of 5/16 hose was worth the lower idle speed to me.I understand that the water is plumber through the throttle body to keep condensating moisture from freezing in cold climates, which may effect evaporative emissions or something else.
As far as checking it for air bubble...disconnect the water line and while you are filling, wait for water to come out of it, then put it back on, thats the best I can think of. I am not sure if this location is prone to air trapping, just a thought.
