idle problem
zero_gripS13
Car: soon to be 95 s14 hopefully
ok ever since i did my 5speed swap my car has had an idle problem, i was wondering if anyone had any suggestions.
problem:whenever i put the clutch in while commin to a stop or rev it in neutral, the engine;s revs will start to go back to idle, but will stop and idle between 1k-2k for like 20 seconds, but it varries, then itll go back down to normal idle..any ideas?thanks in advanced
zero_gripS13
nothing?
tiger
yeah mine does that too... it's kind of annoying..It hasn't done it lately. It's like it takes forever for it to go back to normal idle. I'd like to know what the problem is too.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
mine stopped doing that after i plugged the iacv inlet tube with a spark plug, obviously a temporary fix, but it worked.Granted, with this, whenever you fire up the engine cold it will start and then want to die, but after you blip the throttle three times its idle is rock solid. Also, doing this only emphasizes the KAs hot start problem, its almost impossible to start without the throttle wideopen when the engine is hot.
This is just my experience, i guess you could try just cleaning the iacv valve, but plugging it and driveing it around is a good way to see if thats your problem, just remember how i said to cold start it.
zer0c123
Car: 1993 Nissan 240SX Hatch
While the engine is on, try wiggling some of the wires in the engine bay and see if it affects the idle rpm.
tiger
search on the forum for idle issues and you will come up with many results and one of them might help you out.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
mine idles at about 1000-1100 with the AC on or 900 with it off
All_Motor_KA
Car: 1989 240sx SE
That's really high.
Dattebayo
-- pt.1, adjust idle screw-- pt.2, if no change replace IAC device underneath the intake runners
- check/replace IACV underneath intake runners (pain in the as$)
- clean throttle body
- plug AIV valve (S13 only)
-- pt. 1, check wiring/replace TPS-- pt. 2, replace oxygen sensor if problem with TPS (preventative follow-up)
- Check Fuel pressure & regulator operation
- Inspect injector O-rings for damage (pain in the as$)
blah blah blah there are tons of possible problems.
Modified by 2BN_S13 at 10:26 PM 8/7/2005
tiger
hey.... when I mess with that screw nothing happens... so the aac is bad? my idle is a little weird but not too crazy... sometimes it gets out of hand though.
Dattebayo
I fudged that by accident, sorry! The IAC is a slave of the idle screw, its located underneath the intake runners. Its the one that the about 1" hose goes into the tube to the bottom right of the throttle body. You cant really see it too well without a flashlight...
Actually, the TPS is also a slave of that computer programming... I would check it as well...
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
What's so bad about it idleing at 800-1100 if it's super smooth? I got this car new in 89 (well my dad did) and from what I remember it has always been in the 800-1100 range
zer0c123
His description is very similar to the problem i just fixed recently. Rotting TPS wires.
zerothread?id=124683
Dattebayo
The reason I posted the prior post was becuase ALL the KA idle issues have roughly the same causes. If you simply follow the proper procedures you will eventually find the issue.
aesic
Car: '91 S13
What should the KA24DE idle at? I bought my car a few months ago and it idles between 1k and 1.1k. SOMTIMES 900, but usually 1k-1.1k (no AC). Is this bad and should I correct it, or is it okay to leave as is?
-aesic
InsanityInc
stock idle is 700rpm
aesic
Car: '91 S13
How would I go about changing the idle from 1k-1.1k back to 700 or 800? Or, what could be causing this higher idle?
-aesic
Redline_180sx
Car: 180sx
my car has the same problem... I figured it out that the injector harness was bad... now I need to find some, dealship charges 200+, they won't sell the clips alone....
anyone have some the can sell me?
Dattebayo
FSM lables the Idle to between 550-800 rpm for manual transmission, as I am betting most of you are.
