em0eric »
https://forums.nicoclub.com/em0eric-u28462.html
Wed May 04, 2005 5:20 pm
Hi guys, got a problem i need a little help with.
I drive a 1990 240sx (sohc) For awhile now my engine check light has been on with the error code for fuel injector leak. So yesterday i finally receive the injectors that i baught (stock) and put them in. But now my car idle's really really rough. it's never been this rough, it shakes my car very noticibly even from the outside. Whenever i go into 5th gear it shakes so bad i feel like somethings going to blow up if i stay in 5th.
Also when im in the low gears like going from nuetral to first is shakes as bad as it does in 5th gear. I know that the 240 has idle problems but this is something else. I can also feel that i dont as much power as i used too.
Any help is appreciated. Here is pretty much the procedure that i followed when taking them out. it was from another post here somewhere.
"now for relieving fuel pressure basically wut ur gonna wanna do is remove fuel pump fuse (10amp) placement of fuse is behind battery. the second red 10amp fuse from the front of car is fuel pump.basically start engine and let her run till she stalls. thus relieving the "majority" of fuel in fuel lines.
then reinstall new injectors with NEW seals if possible."
to get the fuel rail loose i had to take off a few hoses that were directly above the fuel rail but i put them back on.
