idle problem
scottsnissan
Car: 1995 240 sx se
1995 240sx se
Jus finished from new head and head gasket. Car has a hard time starting like its not getting fuel.Jus got new pump and the same.(takes about 6 cranks before it idles).After it cranks it sits at 1800 rpm which i think is haigh and takes a good 5 mins or so to lower.Aslo when driving as i come to a stop and put in neutral car revs up to 2000 and then drops to 1000 where it runs.Do u think its my tps or anything else.?
my89240sx
Car: 89 240sx
what's the temp gauge reading prior to the idle dropping? 1800 would be correct for a cold start while the thermostat is closed. Have you checked the thermostat? It may be sticking open causing your car to take longer to come up to a normal operating temp. As for the high idle, you might just adjust the idle down a bit and see what that does.
ILikeMy240sx
Car: SR Power
1800 does sound high.. My cold start is around 1300 RPM.
Maybe a leaking intake manifold? You can try spraying the area with carb cleaner and see if that kills your engine. Also, try adjusting IACV idle screw.
scottsnissan
Car: 1995 240 sx se
Well the intake is not the case.I was told aic today was probaly whats causing that but not sure .Like i said when driving she come down to around 900 idle but when i start to stop it first jumps around from 900 to 200 around 3 times then idles at 900-1000.Remember this car sat for a while i mean 2 yrs or so.
