idle problem plz help!!!
davidfrost240
Car: racing
my car will idle fine until i do these things: push in clutch, press on break, open door, turn on lights, and any other electrical thing.
my idle will drop if i do any of these things could somone plz give me some pointers on this problem thatnks!
drjohn
Vehicles now days need a specific amount of voltage to operate properly. If the battery cables,connections,or battery itself are bad this will cause this condition.Check and make sure you have a body to engine to chassie grd.and connections are clean.If these are in good order than you probably have a alternator output problem,low voltage or amperage which may require alternator replacement.If when you start your car and the warning lights stay on this is a good indicator of alt.problem.
