guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Sat Jun 02, 2007 8:36 am
Well after all this I went out about an hour later and ran some errands and it started doing it again. Turning on the a/c steadied the idle some, but made it really high (about 1200-1400 rpm). So, this time, I disconnected (with the engine running) the throttle position sensor plug, and right away the idle steadied right at 900. I bent the contacts slightly, and plugged it back in. The idle dropped to about 800 and after about 100 miles since doing this the idle has been rock steady and it runs great again. You might try this....?
