idle problem (i looked around but really cant find a specific answer)
koolcat
well i changed all the accessory belts on my 92 240sx and after everything is replaced my idle is really rough. it would drop from 800 or 700 rpm to like 200 n bounce back up to 1000. Also sometime when i drive and push it hard and put it in neutral right away my rpm would fall until it stall and it is dangerous. So please, if anyone has the solution to my problem lmk... THANKZ
sky20sx
Car: 1993 Nissan 240sx
Hey, you might want to check and make sure you connected all the vacuum lines that connect under the throttle body
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Check for a sticking EGR valve.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
my car similarly had a bouncy idle. I checked all the vacuum lines and didn't find any problems. But my timing was at 15 BTDC instead of 20 like it's supposed to be. I advanced my timing to 20 BTDC and it idled fine after that.
