nismo s-13 »
https://forums.nicoclub.com/nismo-s-13-u88111.html
Wed Mar 12, 2008 2:48 pm
Hi every one my name is Johann i live in P.R. and not too many persons around here now how to work with a KA24de dohc 1993 nissan 240sx, so I was wondering if someone could lend me a thought so heres the deal my car was recently rebuild new pistons, eagle rods (good), timing chain, and some other things. my car was idling about 700 so i took my manifold out and took the liberty of eliminating the butterflys in the intake manifold, when i installed everything back together my car started fine but later on it started to see blackish smoke coming from the pipe so before i took the butterflys out it did it so i thought maybe it needs more air for the mix maybe it has too much fuel, i dont have a FPR im in progress just waiting for the a fittint to eliminate the OEM FPR and install a new one so I have B&B spark plug cables and platinum NGK sparks I took out the pair valve and the other emission system like the EGR including the tube and sealed it, I checked my car for vaccum leaks and it showed none but it has recently been turning my spark plugs black, I dont know what to do Im getting desperate and angry ohh my ignition I dont know if its good or bad. I defenetly need help expert advices i want my car to be running and kicking as... so please someone!!! I Still need to get rid of the fan clutch I hate it so much! normally when im crusing that I shift back from 4 to N it sometimes the RPMS go from 1000 to 500 and back and forth back and forth and you can see the black smoke coming out what could it be it doesnt do it all the time, just sometimes, but the other day i had to make a sudden stop and it turned off quickly when I stepped in the clutch it idles in about 1100 cause the only solution i saw to this was to forward the distributor and now when i turn my A/C on, the car lowers the RPMS insted of raising them what the heck is happening I have so much problems and I dont want to sell it case I love the car. Thanks for hearing me out!
