NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon Nov 10, 2003 11:21 am
if you pinched that line you basically choked the engines only air intake( if its the inch diameter hose going to the intake manifold) the car should of died or came very close to it. unless the car wasnt warmed up. If the throttle plate is closed and you pinch off the only line coming from fresh air to intake, where is the engine suppose to get its 14.7 parts of air for that 1 part fuel?
you could have an intake air leak somewhere.
