saturnvii7 »
https://forums.nicoclub.com/saturnvii7-u63952.html
Mon Dec 03, 2007 7:38 pm
Thanks for the responses. I'm at home now and just took some pictures of the engine compartment. I definitely have the CHTS installed if it's between cylinder 5 and 6. It looks like there's another port that is filled slightly further back at the rear of the engine compartment (6th cylinder), but that could just be for the heater.
Is the CHTS the only thing that would cause serious stalling/idle problems on an otherwise smoothly running 280zxt? The manual also references the EGR valve being a source of a rough idle, but I don't think it would cause the engine to stall completely. I'm also missing the air regulator.
The surge I was referencing was a general oscillation of the boost that seems to coincide with the rough idle. Once I'm up to speed (10+ mph) it sounds and pulls great, so I'm pretty sure fuel system is okay. I took some pictures of the engine/sensors tonight but unfortunately I don't have a way to transfer them to my computer tonight. I'll try to do so tomorrow.
It looks like everything on the top of the manifold combines to run into a pressure regulator on the injection harness, I'm guessing it adds extra pressure to the fuel lines for idle and full open throttle? Right now it's hooked directly to the intake manifold, but it looks like it would generally get input from the fast idle controller, air regulator, vacuum control valve and to the pipe coming out of the turbo.
Do you think I just need to replace the CHTS? Looks like it should be fairly simple to replace... I'm wondering if some component malfunctioning is causing the problem or whether I'm missing something essential. I seem to be missing the cold air sensor as well, and there's a electrical hookup lying dormant because of it. I'm planning on replacing everything necessary but right now I'm just trying to get it driveable. In other words, a 5 spd is definitely in the works... it's just a little low on the list right now. I'm in Arizona and unfortunately the 81 didn't come with an intercooler stock...it's okay now but it'll be killer in the summer. That's definitely next up once I get it driving right.
Modified by saturnvii7 at 12:18 AM 12/4/2007
Modified by saturnvii7 at 12:26 AM 12/4/2007
