lestion »
https://forums.nicoclub.com/lestion-u3503.html
Thu Apr 24, 2003 1:00 pm
Hiyas again gang,
My 96 turbo KA is alive and kicking, with a couple of what seem to my thinking to be 'minor' problems. I am currently runig 10 psi of boost and the car is out of hand fast. The one thing I can't seem to get past is this idle problem. The car will idle fine when it is cold, but once it's warmed up, and the idle drops a bit, the engine gets rough and the idle is VERY unstable. It 'hunts' for an idle speed and will eventually die (maybe 30 seconds at a stop light). I have talked extensively with Jim Wolf and we have gone through the paces i.e. checked fuel pressure, adjusted both up and down, checked for vaccum leaks on each side of the manifold, adjusted MAF location and seal techniques to check for air flow problems. I have double and triple checked timing settings, checked valve tappet clearance, run a pocketlogger to check O2 sensor voltages and tried to keep the car in closed loop operation under load to see what settings come through. Here is what I have determined thus far: MAF at idle=1.15-1.19 V. O2 Front sensor seems to be cycling at factory spec.
Lemme give you all a rundown of the vehicle so maybe to paint a better picture:
Forged Rods and Pistons 8.0:1 compression255 LPH WalbroDenso 660 cc injectorsJWT ECU Flashed for Z32 MAF and Densos listed aboveZ32 MAFGreddy type S BOV recircing into intake tube AFTER MAF, but BEFORE compressorIACV hose fitted to charged air pipe just before Throttle BodyValve cover breather to MAF/Compressor tube AFTER MAFT3/T4 hybrid stage II compressor wheel/ .48 exhaust housingApexi generation I AVCR
The boost gauge, BOV and Boost Pressure Sensor are all plumbed into the FPR control line from the back of the manifold on seperate T's.
So with all this please let em know if ANY of you have any ideas on what could be the problem. The car 'feels' like perhaps there is a miss in it up to about 2000 rpms, after 2k, it just pulls like a banshee. I would love to turn this thing up to 17-20 psi like its been built for, but I am afraid to until I have this problem sorted out. Any ideas would be greatly appreciated!! HELP!
Thanks all, sorry this was so long, but I figured, the more info you had, the better it would aid in diagnosis.
Marc
