frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Fri Sep 12, 2014 8:56 am
Welcome to NICO!
Glad to see you're enjoying your Z.
Have you been up on the maintenance? It may be time for a tune up. In addition to the fuel filter, try cleaning the Idle Air Control valve, the MAF, and changing the plugs/wires. You should also check for vacuum leaks by spraying carb cleaner on/around vacuum hoses. If the engine revs or races up, you've found a leak. Visually inspect the suspect hoses for cracks and breaks. If the issue is vacuum related, it is tiny considering your symptoms.
