SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue Feb 10, 2004 4:59 am
Do you have a BOV? Some SR's with BOV's and preset higher idles will stay up at 14-1600 RPM's until the car comes to a full stop. At least thats what my car does whenever the BOV is installed. Also if the BOV is too loose it will vent the air at 80% throttle, thus the shuddering may occur because the air that was supposed to go into the cylinders is now floating around your engine bay.
Also on a relatively stock SR, if the idle is set improperly (aka wrong level) the idle will idle hunt, have high or low idle, and have a lack of power/poor acceleration. The same symptoms can be caused by the TPS being incorrectly adjusted. There is of course the chance that the ignition timing is slightly off, so be sure to check that too.
The coolant sensor would be last on my list of stuff to check since it doesnt result in the symptoms you named.
Just a thought assuming you meant to type SR20DET and not RB20DET.
