Recently been having issues with my 233k+ 01 QX4 , so i need to stop being hardheaded and get it fixed before it gets worse (or is it already?)
Couple weeks ago, I experienced my car going maximum 30mph and couldn't pass 3k rpm. Almost got rear ended when headed for work at 7am. (Somehow spraying Mass Air Flow Sensor Cleaner, fixed it temporarily)
Recent Symptoms:
- After a cold start-up and forward progress, the idle revs up & down between 1-4k rpm and the car hesitates to move. After a couple seconds, it's fine.
- Sometimes when idling, the rpm drops below 1k and then back to normal. Once in a while, the rpm drops to zero and i'll have to start the car again during a stoplight.
- When idling, there's a weird smell coming from the exhaust. Smells worse when idling in a drive-thru.
- Not sure if this can be a part of the problem, but my oil cooler is leaking. I recently bought the small and large o-rings on ebay. Waiting to replace on my next oil change.
Your help is greatly appreciated!
Here are the codes:
1. P1145 - Manufacturer Control
2. P0171 - System Too Lean Bank 1
3. P0174 - System Too Lean Bank 2
4. P1145 - Manufacturer Control
5. P0171 - System Too Lean Bank 1
