cb_240 »
https://forums.nicoclub.com/cb-240-u36987.html
Sat Jun 21, 2008 4:00 am
Rb25 in an s13
car is running fine, the idle is at about 1200-2200 (it varies from time to time after i turn the car off and restart it) I've got a q45 throttle body on it on a greedy style intake and i've adjusted the screw on the throttle body out and i've played with the screw on the aac valve (now all the way in) and this is as far as i've gotten
What is really giving me a headache tho is when the car idles (stopped at a red light, or just sitting after start up, etc.) the car fluctuates between 1200-1800 rpm constantly
like it goes up to 1800 then drops off and up and down etc. and just keeps doing it. If i rev it it stops for maybe 3-5 seconds then will start doing it again, i'm just wondering what is causing this and where i should look to solutions.
I read somewheres about needing an aftermarket fuel pressure regulator to compensate for the walbro fuel pump?
please help, I got a taste for the RB and I want more
