idle issues and backfiring?!?
DBo
Car: 1993 240sx Sr20det
my car is running odd and i cant figure out the problem. when i start up it runs and sound fine but once its warmed up it idle erracticly and wants to die. im also runnin rich and back firing. i checkd all my vacuum lines and I/C couplers. im goin to boost leak test it tomorrow.
can anyone help me figure out the problem.
thanksdbo
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Boost leak it. Check plugs. Check Timing. Just to be on the safe side.
DBo
i checked plug i jsut changed them and timin is dead on but i am goin to re check it. ima boost leak test it tomorrow... any more info?
slideways21
i have the same damn problem
DBo wrote:i checked plug i jsut changed them and timin is dead on but i am goin to re check it. ima boost leak test it tomorrow... any more info?
I have the same damn problem.. Let me know what you had to do to fix this... I've check plugs,timing,cleaned maf/iacv, checked for boooth boost and vacuum leaks..
dc1984
Car: 93 240sx/98 180sx blacktop sr20det :RIP/ 93 jeep grand cherokee
try checking 02 sensor. mybe it went bad and when it gets hot it starts sending the wrong signals to the ecu. the o2 sensor is supposed to mostly work when it is hot so i guess it would kinda make sense for that to be the problem.
hopefullt this helps
Blown240sx
Car: 1996 240sx
ECU Coolant Temp Sensor
DBo
Im checkin everythin today...changin out the temp sensor today ill jsut swap it out at work. my Fuel pressure is right. i noticed today when driving it surges abit.
ill let yall know wats up later today
anyone else?
DBo
changed the coolant temp sensor seemed like it helped a little. its not dyin as fast. i frgt to mention i ran some seafoam in it. could the seafoam mess up my injector o rings?
jetblack24
Car: 1990 Nissan 240Sx
Do you have the stock FPR or an Adjustable one? if you have the stock one switch it to an adjustable. If its adjustable get a fuel pressure gauge and make sure its right. With the vacuum it should be like 43psi w/o it should be 35 i belive... check the numbers behind me. Im not one hundred percent positive.
DBo
i have a sard fpr and my numbers are right i will triple check though thanks
anyone else?
jetblack24
did you ever run that boost leak test?
DBo
no i had to fix the boos leak tester i hsould ave time to do it tomorrow hopefully.
today when driving back from work it drove fine then suddenly car dies. start it back up and dies again it didnt want to hold idle. so i just kept feathering the gas to keep it on then when i can to another stop it held idle.
could it be the IACV? can seafoam f*** that up?
jetblack24
did you put the seafoam in your gas or intake? if you put it in your intake then yeah...i would clean your iacv just to be sure. and if you have a blow off...cut your car on and let it idle if it will and put your hand over it...if its letting a decent amount of air out on idle tighten it....that could be your boost leak.
DBo
yea i put it in the intake:( through the vacuum system
jetblack24
i would take your iacv off and clean it with a rag, a toothbrush, and throttle body cleaner and then see if that doesnt help at all.
snake240
Car: 92 hatch SR20DET
i agree with jetblack. take that iacv off and clean. theres probably alot of buildup in there.
vanquish2
Car: 92 240sx
what plugs did you use? one heat range off can cause this prob.....
cody180sx
Car: s14 rb25det fully built 550whp coming soon
i would put my money on a boost leak. 90% of problems with the sr20 are boost related
Sr20S13Det
Car: 1991 240SX Redtop SR, 1989 240SX Parts Car, 2000 Ford Ranger (DD)
Seems similar to my problem. At idle it kinda jumps around. When i come to a stop sign and push in the clutch my rpms drop and i stall. Smells like its running rich. i gotta rev it to keep it running after it warms up. racking my brain of what could be wrong. I sprayed carb cleaner into my iacv and didnt work. i guess i should take it off and actually clean it. it ran fine then this past weekend my friend and I boost leak tested it and fixed them all. ive been told possibly the Throttle Position Sensor. i havent gotten a chance to test the volts yet.
Emperor_Tha
Are u running rich all the time or only when it acts up?
U can alway unplug the 02 sensor and see if it drives better.
DBo
update:i drove long up to shreveport from new orleans about 5 hour drive. when i got their it didnt do it anymore. somehow it fixed itself. but i do still think i have a small boost leak. just have to check where
