tt90z wrote: ↑Tue Jan 23, 2018 11:39 pm
ok, replaced idle valves with new ones, replaced the injectors and checked over and over and over for boost and vac leaks, tested wiring meticulously with a dvom. tried a different ecu, re checked timing and tps and did another compression test.
think i need to just count my losses and sell this and walk away.
OK, next step before bailing is to check the PTU harness connectors, all four of them (both halves, two connectors) for corrosion. The PTU can be an issue and was with mine, replacing the complete harness FINALLY fixed the similar issues I had as yours, and after doing as you- replacing damn near everything under the hood electrical- and idle-related.
Can't hurt to check, one side (original non-shielded connection) most likely will be VERY green with crud while the other, newer shielded end will have no corrosion whatsoever. Damn Nissan used the old crappy connectors to connect the PTU but then used new ones for the PTU service call replacement harness connections- awful nice of them, eh?
