Mines is currently just below the 500 line. Can you be a little more specific where this screw is?-RJ- wrote:i have mine set at 750ish
All is done except these 3. Will try... Thanks.Eikon wrote:It's either mechanical or electrical.Remove and clean the AAC. Remove and clean the throttle body. Reset the ECU
hey "linkmaster"........ahhh, I mean Seth, gotta link to cleaning the AAC?Eikon wrote:It's either mechanical or electrical.
MechanicalCheck for vacuum leaks. Remove and clean the AAC. Remove and clean the throttle body.
Electrical. Clean the MAFReset the ECUcheck for shorts in wiring on throttle position sensor.
no prob man. Same goes for me.. except the 12 hour day part. lolBiXLL wrote:LOL, I use that line all the time myself!!!! Thanks man, you just helped a guy that put a 12 hour day in and is admittedly being lazy!
