idle is too high?
HIcoupe
Car: 1992 S13 Coupe SE
what should i check for if my idle is about 1500 rpm on neutural? is that normal? also it seems like its bouncing when driving off in first?
Klits562
Car: white s13 coupe
check for vacuum leaks or try adjusting the screw on your idle air control valve(iacv) search for it on here theres a thread or write up for it im sure
