Idle is surging?
burntricer
Car: 90 S13 SR20DET Redtop
hey all, i just replaced my IACV with a brand new one...now i have a surging idle problem, it hovers around 2000 rpm... thats with the mafs unplugged...with it plugged in it goes up to 2500...
just curious if i should re-remove my intake and change my IACV again... and i went over all my wiring and the mafs wiring checks out.
anyone got any other suggestions?
thanks
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Is the IACV getting 12 volts?
burntricer
sure is, all wiring is well within spec. its not sticking either, cuz as i turn the screw out, the idle will pickup...
when i pinch the main feed hose it slows the idle
boro drift
And no boost leaks?
burntricer
not one
boro drift
Did you check for codes? Also, incorrect timing can cause problems.
burntricer
timing is 16 btdc, code 55... were good
boro drift
How did it idle before you changed the IACV?
burntricer
it idled at the right rpm, but it ran super rich.
boro drift
Then you should re-trace your steps. It has to have something to do with the IACV replacement. Possibly a air leak between the IAVC and the intake, or intake gaskets themselves.
burntricer
im thinking thats the plan for tomorrow, i know i tightened shiv down again and it seemed to help a lil bit, im wondring if the actual IACV is leaking around the gasket or around the solenoids'
boro drift
You did use all new gaskets, right?
burntricer
all my gaskets are new MLS gaskets
but yes, i did use new gaskets with a dressing of Anerobic flange sealant
boro drift
Well, just look it over real good tomorrow and let me know.
burntricer
sounds good, i think im gunna pull the upper intake off and re-snug the iacv.
you use msn messenger?
boro drift
No, you can just post back and I'll read it.
burntricer
what are the tq specs for the IACV?
boro drift
They're 6mm bolts, so 5-7 ft-lbs. Not much.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
leak between IACV and said gasket....
burntricer
really? i just checked it and it seemed fine....but i found when i clamp the IACV hose, the idle shoots down to where its supposed to be.. is that a blown iacv then?
boro drift
Find any faults or make any progress on the prob?
burntricer
i think i just found something, i went to change the gasket, and the IACV has coolant passages, one was blocked by something... could it have a temp sensor in it maybe? or even a coolant reliant cam or something in it? i know the s14's have one in the tb.?
boro drift
That may have a little to do with it. Make sure the coolant is free flowing through the IACV. And two more things, 1, is the idle screw all the way in? 2, is the brake booster hose connected? Simple stuff, I know, just trying to narrow it down.
burntricer
i think silviak's nailed it. i changed the gasket at the IACV with the old one, put some anerobic sealer on it, now it idles around 1500, but it came down to 1000 at OT. so im thinkin were good. but it could have been me re-torquing everything again.
boro drift
Sweet man! Glad you got it fixed.
burntricer
we can hope!!
