idle is rough
240dreams
Car: 240's
what can be the symtoms of a high idle(1.2k around there)? I think my throttle cable may be messed up.
Dattebayo
most likely either your oxygen sensor is going bad or you need to adjust the idle screw.
quiksilvia
Car: 95 s14 se
i just installed an afr gauge and when i did, i noticed my 02 sensor was some kind of funky-the point im getting at is if u do get a new one, dont pay the $80 at the dealership-go to autozone and pay 40.
Touchdown038
Car: Computers, cars, sports
Are you getting really bad gas mileage? If not, you can scratch out the O2 sensor as a possibility. If there's any doubt in your mind, though, in the FAQ section of 240sx.org, there is a procedure to test your O2 sensor. Go check it out and then decide if it's your O2 sensor. Just trying to save you $40.
240dreams
Car: 240's
Thanks you very much guys. Great info and support. It does seem to eat gas kinda quick. Also when i floor it hesistates a little. Thanks again for the info and not just blowing me away for asking a newbie question.
240_Keyy
Car: '90 240 Fastback
actually, that was a decent question. I have my SR idling at like 1200rpm's cuz if I don't it starts to get all jumpy with the idle. Crazy stuff...
Meantime
Mine was idling at 1500 recently...turns out it had a clogged O2 sensor. It was running rich, hesitating, sucking gas, all your symptoms, basically.
If you find that's the problem, and you replace it, you're probably going to need to clean/replace your plugs as well (mine were black-fouled from overly rich mix).
trpower7
Rough idle can be any of a dozen things. SEARCH for rough idle, it's been discussed a million times.
240dreams
Car: 240's
wtf?! i replaced the o2 sensor but still have high idle, horrible mpg, hesitation, etc. someone plz help
FrEaK
Car: Boosted D21 Pickup
Check your AIV connections and valves, and your IAA, older cars tens to have idleing problems when these go... check them...
Also it doesn't hurt to run some tb cleaner through your system... there is also a good chance your throttle plate is staying slightly more opened then it's supposed to, this has happened with cars that have cruise control...
Check your sensor grounds...
