S14-NEO »
https://forums.nicoclub.com/s14-neo-u25945.html
Thu Mar 17, 2005 6:45 pm
yes set it back to base timing very easy to do. get it to TDC if you have the valve cover off just look for the front lobes in both cams , they should be pointing away from each otherintake cam pointing to right fender(pass) and exaust cam pointing to left fender (drivers). second look and the crank pulley and make sure it is set to TDC, should be the very first line.remove the CAS and look for the sqaure notch and line it up with the yellow dot furtherest from the gear or CAS then slide it back in. when it slides in the gear will rotate and then line up with the next dot . that should be base timing, very simple. good luck
