tollboothwilley wrote:true...but he is missing gaskets. Those need to be there regardless. I would make sure I have at least one. Removing the TB spacer isn't gonna fix the issue. Its not the TB spacer causing the problem. I have the same one installed, no problems.
I get the feeling that most of you think I'm out to negate your mods. That's not the case. What we DO need to look at here is that Vivek's car is like Christine. It has a mind of it's own and has probably seen a mechanic more times than any of ours - No offense, Vivek.
As such, the only "unique" mod he has that the rest of us don't is the TB spacers. I believe that a vacuum leak is a very possible culprit, but a lean condition among others could also be causing the erattic idle.
Since the TB spacer is easy to remove, it's the logical first move in troubleshooting.
