idle gone horribly wrong... PLZ help
0range_240
Car: 89 HCR32
As the thread says, my idle for the last week or two has been absolutely horrible. When I first start the car in cold weather it goes up to 1500 and stays there, occasionally dropping to 1000 for some reason and then instantly popping back up to 1500.. once the car is warm it idles fine, EXCEPT when the motor is fine and I turn it off, and then I let the engine sit for 2 minutes at start it up again.. what happens is the idle climbs up slowly to 1800 and then drops instantly to 1500 and then starts going VRM.. VRM... VRM...VRM.... shooting up to 1800, and then falling back to 1500 and repeating over and over, and the frequency of it gets slower and slower until it finally stops... what the hell is wrong with my car?
Any help for this poor sap would be appreciated guys :confused:
[s3]
Check for codes, and looks like MAF problems.
0range_240
Car: 89 HCR32
What kind of chemicals can I use to clean the MAF.. I am not too sure if I have carb cleaner... would WD40 work? (forgive my stupidity if thats way off)
[s3]
Don't clean the MAF. If its broken you need a replacement.
Check for codes.
0range_240
Car: 89 HCR32
okay, how much is a MAF anyway?and if that doesnt solve the problem then what? bad injector?
TachyonS14
I heard on S13's (by looking at your profile looks like you have one) that removing the AIV system usually solves a majority of idle problems like this. You could try this:
http://www.nissaninfiniticlub....moval
Hope you fix the problem!
Kelso
Car: bass,punk rock, surfing, cars
errrr...i thought that was pretty much normal?well the first part of it anyways. when mines cold it will idle anywhere from 1g to 1500....after the thermostat rises, it drops down to about 800 or so.on occasion it will drop to like 600 and almost die when i try to go. do you think mines ****ed up or is that pretty much normal for winter months?
TachyonS14
When a car is cold and you start it, the idle should be high. But, then it should slowly drop down. He said his drops down, then shoots back up etc.
0range_240
Car: 89 HCR32
yeah and it does it fast, like bounces up and down between even 1200-1800 maybe once a second like someone was literally revving the motor.... Ive never come across something like this.. I hope S3 is right that its just the MAF but I dunno
Right now im more concerned with fixing my blower motor... my other thread isnt getting much attention, any of you guys know where the blower is and how I can take it out?
0range_240
Car: 89 HCR32
btw, I removed my AIV system a while back, the problem got no better/worse from it, although I did notice better throttle response O.o
Anyone know how much a MAFS costs?
GuSpeed
yea i want to know how much maf cost as well and what it looks like
hondahunter180
Car: 2003 audi a4 - 1969 bmw 2002 - 1990 s13 (sold)
ive got a maf, its used, but should work fine
0range_240
Car: 89 HCR32
First I gotta check to see if mine is toast, but if it is.. how much you want?
0range_240
Car: 89 HCR32
Aight update.. I ran the diagnostic mode on my ECU.. didnt throw any codes, got a 55 "everything A okay" ... so, what now?
ricebike
2002 Quest
2005 Altima
http://www.nissaninfiniticlub....26039 check & mebbe clean 'em out... check vacuum hoses as well; i had a broken hose to the BPT valve when i was replacing injectors... check the throttle body intake boot for rips...
that's all i can think of...
xxtrizz
Car: Cars, computers
Yeah its gotta be something small like vacuum hoses or Intake MAF or something. My car when its cold never drops at all its crazy. But when its warm outside and I start it it drops down to like 300 after about 3 seconds at 1000 then zooms back up to 700 wierd. My AIV isnt out either.
OH and if you want to check your vacuum hoses do what the masters told me to do take them out and blow on them. hahahah man I will always cherish that one.
MikeMurphy
Car: Guess
Probably wouldnt be the MAFS because as you said, once its warm then its all gravy.
Not sure beyond that but I would rule out the MAFS with 95% certainty.
nightwalker
Car: 240sx
I have the same problem. I can't figure it out. Post your findings.
0range_240
Car: 89 HCR32
Im not sure which vaccuum hoses to check and where to find them?
PapaSmurf2k3
Site Admin
i had problems like that... i replaced my TPS and cleaned my throttle body and they all went away.
cowboyrps13
Car: 89 camaro, 89 240 hatch
just in case it is the MAFS, from the dealer here in NC its 530 bucks, thats including tax, i just replaced mine :( although it is nice and shiney now :D ooo and i had close to the same problems your having, with idle jumping and dropping, so far this has fixed it, when ur idle starts dropping really low to the point of dying, or jumping up high, pop the hood, get out and beat on the maf, if it returns to normal, then good chance thats whats wrong :eek: thats how i found out :D
