Idle Fluctuation
CakeEater
Car: '93 240SX w CA18, '08 Titan Pro-4X
Hi all,
I finally started my CA this weekend and was good until it got warmed up....The idle jumps between 1200 and 800 rpm. The fluctuation has a perfect rythm to it.
EDIT: It is a full OEM rebuild motor with all new gaskets.
The battery is dead and might be un-usable. I have to use another battery to jump start it.
It also has the AC fan running on it.
After all that is said...I think that the idle fluctuation is the alternator trying to charge the maybe toast battery and running the fan.
I'm going to get a new battery soon and see what happens.
Any opinions are greatly appreciated.
Thanks.
meminto
Car: S13 Silvia CA18DECT
I would also inspect your air regulator...
CakeEater
^ Will do....I took it all apart to clean everything so I maybe didn't get it back to the same spot.
Modified by CakeEater at 6:13 PM 10/13/2008
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
meminto wrote:I would also inspect your air regulator...
I would be checking for vac leaks as well.
DALAZ_68
Car: 90' 240sx CA18det
i would also say grounding points...or maybe add point to it
CakeEater
I have many grounds on both the body and the motor....HKS circle earth
