Idle Fluctuation...
NICONick
Car: 1993 S13
OK, so recently ive been experiencing some problems with acceleration and the acceleration has been not smooth through the gears and then today the idle was going crazy and eventually caused me to stall when pulling into my apt complex..what could be wrong?
NICONick
Car: 1993 S13
anything?
tetsuo
there's a lot of things that can be wrong but a lot of times the problem will appear with either an ecu error check or a very careful visual inspection (intake air passage, everything to do with your sparks (from the plugs to the coil,etc.)
180fan
Car: 89 fastback
any noises, at or mt, when was the last time you've done a tune up, have you given your iacv a cleaning yet, etc.
Needs more details.
