mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Thu Feb 13, 2014 7:56 pm
Today I swapped MAF sensors between my car and a buddy's Q45 to see if the idle and cruise stumble problem moved to his. I still have the same issues. If the idle air control valve is connected and it starts to increase speed at idle momentarily, the valve tries to bring the idle back down and when the momentary increase in RPM goes away, the RPM drops off even more and the valve then tries to compensate and bring the speed back up which it then over compensates and I have to hold the brake pedal harder to keep it from moving when at a light until the RPM settles back down. If the valve is disconnected, I still notice the RPM jump up around another 100 rpm and then settles back down but it isn't as aggressive. I don't know what can cause the rpm to increase like that when the idle control valve is disconnected. I checked the wiring to the ECU by wiggling the wires to try and provoke problem like Wes said to try but nothing would happen. I'm not sure what else to check at this point. You see my fuel pressure readings in my previous post.
Matt
