Idle engine shudders after installing intake
All things Altima Coupe.
caldwellac
Car: 2010 Nissan Altima Coupe
I wanted to see if anyone else has had this problem and fixed it. I recently installed a KN intake on my AC, when the car is in drive but I am idle, say a traffic light the engine shudders. If anyone could lend some advice it would be greatly appreciated thanks.
Ranga14
Car: Boosted 08 Altima Coupe 3.5
Check your MAF sensor and if it's installed correctly or if it's dirty.
caldwellac
I appreciate the feedback. What kindof cleaner should i use to do that??
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
I think you can buy a spray cleaner specifically for mass air flow sensors and an auto parts store can recommend one.
caldwellac
I bought the cleaner and removed the Amf from the intake but I wasn't sure which part to spray down. By looking at it I want to go as far as saying I might have to replace it. If anyone has had any experience with an AC type AMF I would appreciate any feedback. Thanks
caldwellac
AlexN09 wrote:I think you can buy a spray cleaner specifically for mass air flow sensors and an auto parts store can recommend one.
Hey where did you get your overlays and fog lights??
AlexN09
I got the overlays from bluebatmobile, he's a member on the forums and sells overlays for many cars. Just search his name or take a look in the exterior forums.
I got the fogs from eBay and if you just search altima coupe foglights there are tons of kits out there.
Blue Batmobile
Vendor
Car: 1997 NSX
AlexN09 wrote:I got the overlays from bluebatmobile, he's a member on the forums and sells overlays for many cars. Just search his name or take a look in the exterior forums.
:bigthumb:
B@t™
AlexN09
No problem, bat!! Your overlays are holding up strong and look great after a year.
Blue Batmobile
Vendor
Car: 1997 NSX
Doesnt surprise me ;).
B@t™
TheTrooperx86
Car: 2012 Altima Coupe 2.5s
I am having the same problem after installing my k&n typhoon .... it worked fine for a few days and then it started happening.... to be honest i think the dealer ship screwed around with it .... because it was fine until i took my car in for state inspection
RicerX
Car: '20 Titan Pro4X
Idle Relearn procedure - search for that and you will find your answer.
