zer0c123 »
https://forums.nicoclub.com/zer0c123-u10125.html
Sun May 02, 2010 9:49 pm
It could very well be an electrical issue. I had the exact same problems for years and always suspected the IACV valve or fuel injectors. I ignored the problem for awhile, because the rpm's never dropped to where the car would stall. However, the car starting to stall last winter so something needed to be done. I cleaned out the IACV valve and replaced with new injectors from Deatschwerks. Car ran a little better, but the rpm problem remained.
I discovered that my TPS sensor was the problem. I had repaired the tps sensor years ago because the ground wire broke off. It turns out my solder and e-tape job wasn't holding up. After inspection, the area where I soldered and e-taped was full of green cancer (corrosion build up). I spliced a new connection and now the car runs perfect with no dropping idle on braking.
So check for electrical problems. Jiggle all the wires under the hood and see if the idle changes. Start with the wires that run above your injectors and work your way from there.
