Big Red »
https://forums.nicoclub.com/big-red-u2123.html
Thu Feb 12, 2004 7:59 pm
Idle drops from 750 rpm to 400rpm just as I press the gas pedal, only for a fraction of a second and them the rpms climb normally.
This happens in neutural and when in 1st pulling away from a stop.
Once the car is moving it seems OK but if I am going along at about 25 mph in 3rd gear and coast, as soon as I hit the gas pedal again the engine seems to stumble before it starts producing power.
I had error code 13 (engine temp sensor), I cleaned the connectors and reset the ECM, no more codes but it's still doing the same thing.
Anyone know what this could be.
btw: it's only been doing this since I had the head off and had a valve grind done so I'm guessing that I missed something putting the engine back together.
Please help, I did the same thing with my wife's car and it's kind of doing the same thing so now I have an '89 & a '90 with the same problem:(
