mdmellott »
https://forums.nicoclub.com/mdmellott-u292054.html
Fri Mar 19, 2021 8:35 am
Other than the IACV, what else effects the idle while not moving forward. At a stand still, in neutral or park and with the brake depressed or not, my idle remains at a solid 750rpm with absolutely no variation. As normal, when I put it in drive with the brake depressed, the rpm will drop to 650 and the engine will still be running smooth and normal. However, most of the time, I can watch the tach and see it suddenly drop from 650 to 550 in an instant and hear the engine stumble a bit, so to speak, like a switch just got flicked. As soon as I start rolling when I shift to drive or reverse, without even depressing the accelerator pedal, my rpm goes back up to around 700. My IACV is brand new and this annoyance has been happening even before I replaced it. My throttle body is clean as a whistle as is my MAF sensor, which is also relatively new. Is there some other component, switch or sensor that could be a bit flakey that would cause this? There is never a DTC flagged when this sudden drop happens and I see no other performance issue while driving. I can continue to ignore this and be ignorant about it but I know something's not quite right. Any ideas? Gremlins? I have read through numerous posts about this but found nothing I haven't already checked to remedy this minor glitch. I'm betting it's user error yet I'm hoping there is something someone can suggest that I haven't already tried.
