tmorales509 »
https://forums.nicoclub.com/tmorales509-u51548.html
Sat Nov 03, 2012 2:56 pm
So my car idles normal around 750-800. But when i turn ac on the idle drops to about 500-550 along with shaking. The idle does not adjust itself, it stays down until i turn the ac off. Also the heater does this but only if i put the heater on defrost, if i put it on the front vents or the lower vents it does not do this. There is no voltage drop just the idle. I know that is it normal for a little idle drop but up to 200 with shaking and the idle doesn't compensate i think is not normal. I have changed the iacv with one i got at the junkyard. Im sure there is a small chance that that one may be bad but i don't think the odds are that great are they?
