s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Fri Jun 20, 2003 9:14 pm
ok here is basic inspection for 94 sentrai will try to get one for obd2 as wellalso i will post how to enter self diag modeeventually i will try to get individual components on here
IDLE SPEED/IGNITION TIMING/IDLE MIXTURE RATIO INSPECTIONI.perform diag test mode II(self diag results) A.ok, go to 2 B.ng, repair or replaceII.check and adjust ign. timingIII.check and adjust idleIV.check heated oxy sensor A.ok, inspection end B.ng, check ho2s harness 1.ok, check co% a.ok, replace ho2s b.ng,check emission control parts 2.ng, repair or replace harness
START
visually check the followingair cleaner clogginghoses and ducts for leaksegr valve operationelectrical connectorsgasketsthrottle valve and throttle position sensor operation
start engine and warm it up until water timp indicator points to the middle of gauge.ensure engine stays below 1000 rpm
open engine hood and run engine at about 2000 rpm for about 2 min under no load
perform diag test mode IIif ng, repair or replace as necessaryif ok, continue
run engine at about 2000 rpm for about 2 min under no loadrace engine 2 or 3 times under no load, then run engine for about1 min at idle
select "ign timing adj" in "work support"touch startor without consultturn off engine and disconnect tps harness connectorstart engine
race engine 2 or 3 times under no load and then run engine at idle speed
check ign timing with a timing lightorange notch is zero
check idle speedread idle speed in "ign timing adj" in work supportor without consultcheck idle speed(with tps disconnected)if ng, check iacv-aac valve, harness, and ecmif ok, continue
race engine 2 or 3 times at no load
see "m/r f/c mnt" in "data monitor"run engine at about 2000rpm for about 2 minutes under no loadmaintaining engine at 2000rpm under no load(engine warmed up). check that the monitor fluctuates between lean and rich more than5 times during 10 seconds.or without consultset the "heated oxygen sensor monitor" in diag test mode IIrun at 2000rpm under no loadmaintaining 2000rpm under no load, check to make sure that the red led on the ecm or the malfunction indicator lamp on the ip goes on and off more than 5 times during 10 sec
END
check ho2s harnessturn off engine and disconnect batt ground cabledisconnect ecm smj harness connector from ecmdisconnect ho2s harness connector and connect main harness side terminal for ho2s to ground with a jumper wirecheck for continuity between terminal no 19 of ecm smj and body groundshould have continuity
reconnect ecm smj
connect batt ground cableselect "eng coolant temp" in "active test" modeset "coolant" to 20*C or without consultdisconnect engine coolant temp sensor connectorconnect resistor(2.5KOhms) between terminals of ect connector.connect batt ground cable
start engine and warm it up untill water temp indicator points to middle of gauge
check co%(less than 5%)touch "back"or without consultdisconnect resistor from ectconnect ect connector
if ok, replace ho2s, and star overif ng, continue
reconnect ho2s
check fuel pressure
check maf sensor and circuit
check injector(s) and circuit(s)clean or replace as necessary
check ect sensor and its circuit
check ecm function by substituting another known good ecmecm may be prob, but is not likely(yeah, when they are new)
