t.mcginley.jr »
https://forums.nicoclub.com/t-mcginley-jr-u204971.html
Tue Jan 08, 2013 2:27 pm
If the vacuum tubing is original (or more than 10 years old) all of it would be subject to leaks. Assuming your vacuum lines are stock rubber, the get old and brittle. So just by moving stuff around the engine bay you can cause one to break. Check the two big intake pipes for holes and the various vacuum lines running off of them. Also theres a few vacuum lines around the balance tube, check those out. Is your EGR valve still intact, or deleted?
Also, after adjusting your TPS, did you check your timing?
