guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Sun Mar 02, 2008 4:41 am
Yes it does. The TPS, if adjusted too far advanced (in other words, telling the ECU the throttle is further opened than it really is) will produce a regular idle when rolling, but as soon as you stop the idle will creep up about 300-400 rpm higher. I've adjusted a billion of these, it happens like that every time.
Sounds like your TPS needs to be loosened and rotated up and towards the firewall.
(If your car is an automatic, it is not adjusted by voltage readings like 5-speed cars are. Check the manual, it tells exactly how to do it and if you dont do it that way, all sorts of goofiness will happen.)
