new here, just bought a 97 QX4 with 187K. the car idle is at ~1100 rpm and the previous owner said this start to happen after he replaced the TPS. i followed the troubleshoot in the FSM and adjusted the TPS to 4.0V as per specs. but still no luck when i start the engine (sometime i have to crank it more than twice) the RPM just goes high and comes down to ~1100 and when i rev the engine it dies and sound like misfire. yesterday i bought a cheap OBD2 reader and the codes i got were P0105 and P0300, so i erased them and followed the procedure in the FMS to trouble diagnosis for DTC P0105.
with the engine running and idle @ ~1100 i disconnect the Absolute Pressure Sensor, nothing happen , no change in the engine noise or RPM? is this normal?
second , i took the multi-meter reading as recommended by the procedure , and every thing checked out!!!
am here today to seek you help , guide , assistance please to help me get this baby up and running. any little comment or suggestion might help me out as i am not that good with cars. i only fixed my other car 94 accord and replaced water pump and timing belt that was the biggest thing i ever did , so easy on me okay
P.s: previous owner said, the last time he changed the spark plugs was about 4 years ago. no tune ups other than changing oil.
thank you in advance
