HaveBlue »
https://forums.nicoclub.com/haveblue-u1587.html
Sat Dec 28, 2002 12:58 pm
i have similar problems with my 1990 auto. rough idle, horrible milage (16-18mpg), etc. Did cap, rotor, plugs, wires, checked maf, checked engine grounds (in the back of the block to firewall, maf ground to front near driverside headlight etc). Cleaned AIV, IAC/IAA, checked compression, temp sensor, new injectors about 30k ago. Almost everything. Only thing i have left to check is the grounding wire for the injectors and engine harness and i suspect this may be what is causing my poor milage and idle problem. btw plugs are bone white but there is a huge black stain on the rear bumper, weird. how can it be rich enough to spew like that but not leave residue on the plugs?
HB
