idle air seems to be a *****...
90SXSE KA24ET DREAMS
Car: 1990 Nissan 240SX SE 5spd KA24E-T project
on ka24e sohc.. the idle air control valve seems like a ***** to remove...
anyone have an easy way to do this???
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
10MM wrench... only 4 bolts... they come of easy.. unhook the two electric plugs... loosen the screw on the Vac line.. wiggle free... takes less then 5 minutes start to finish...
okay is that the 4 bolts on the side of it?
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
..... What are you taking off??? I hope you're not taking off THE WHOLE INTAKE!
The DOHC IACV looks like this.. the SOHC is a little different but looks about the same it is located on the back of the thing nissan calls the ECCS.. it's held on by 4 bolts...
okay if i get it off?? i can use carb cleaner to clean it?
i don't think i'll get it off tho.. its a hard spot on the sohc.. and 2 fuel lines are above it and i'm not messing with that **** again.
lol but i'm gonna go try taking it off.. be right back.
1 more thing.... are you sure I don;'t need a air intake temp sensor hooked up to solve my problems
kay i took it out and cleaned the iacv and put it back.. started my car and on the first 3 starts the idle went way up to 2,000rpm and dropped down fast and stalled.. i ketp trying to start it after that and then it wouldn't do crap!!!
are you guys sure its not the air intake temp sensor??
i have cleaned my iacv tonight with carb cleeaner... it didn't fix the problem
i tried adjusting the idle screw on it and nothing!!!
i'm going nuts!!!!!
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Make sure you put it back together correctly the first time I did it it was a little off and it did the same thing (idled high) make sure the lil spring is in there right
how do i go about doing that?? i put it back on right.. i just ubolted it i didn't take the iacv apart it self.. i just sprayed the carb cleaner into the little holes and up the nipple pipe where the vaccum hose goes on to.
