RailRoadMan »
https://forums.nicoclub.com/railroadman-u251040.html
Sat Apr 25, 2015 3:15 pm
I have a 2001 Maxima with an erratic idle and code p0505. I plan on replacing the IAC valve and sending the ecm off to get it repaired. My #1 question is, has anyone had any luck (or issues) with an inexpensive eBay aftermarket IAC valve. From the dealer it is $350.00. From local part stores they are between $200.00 and $250.00. On eBay they can be had for $50.00.
My second question is, most ecm rebuilders are requiring the tps be changed and disconnecting the motor mounts before the ecm is hooked back up. I understand the rational behind unplugging the motor mounts, but changing the tps defies all logic. Those of you that had your ecm repaired, did you replace the tps also?
