Idle Air Control Valve?
Kaos
Is the idle air control valve off an automatic 240 the same as a manual 240? I think mine is done. Here is what happens in a short sense: The cars idle just drops when I let my foot off the gas and when I am stopped it will stall. Now my friend has an automatic KA lying around and if the parts are the same he said I could have the idle air control valve.
Chad
Kaos
Nobody knows if the Idle Air Control Valve off an automatic is the same as the one off a Manual. Come on people I figured someone on here would know this.
Chad
oh sorry I forgot. They are both 92 240sx SE model just one is auto and the other manual.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I will run the part numbers at my work this week for you. I can't tell just from looking at it. You never know what small differences Nissan might have made between the 2.
Kaos
Hey man thanks anyway but I found out they are the same part number. Anyway, where the hell is the IAC located at or is it called something different on a nissan? I have the FSM for a 92 nissan but could not find it. Can someone please help me with this........Thanks
Chad
ka24de_510
It's called the IACV or the auxiliary air control (AAC). However, the only way your car should die at idle without it functioning is if you're running your AC. In a manual I'm fairly certain it only comes on when you start the car and when the AC comes on.
I know because I have a manual switch attached to mine, and the engine will even run an electrical fan at an idle speed of about 750 just fine.
It would be a pain to replace; it's back by the firewall (under most of everything else) on the passenger's side. There are some other people online with problems similar to yours, check around in other threads.
